Mounts for TunerView
HRTuning Sat Mar 29, 2008 8:37 pm
Suction cup mounts.
I would have loved to stock these two, but apparently buying 100 at a time wasn't good enough to earn a response from their sales team.
Verified.
http://www.themountdepot.com/RAP_B_166U_p/rap-b-166u.htm
http://www.themountdepot.com/RAM_B_138U_A_p/ram-b-138u-a.htm
http://www.themountdepot.com/RAM_B_138U_p/ram-b-138u.htm
Not verified.
http://www.satelliteradioexperts.com/Universal-Curved-Neck-Windshield-Suction-Cup-Mount_p_309.html
If anyone finds a new one that fits, post it up. Smile
b18c_ej8 Sat Apr 12, 2008 3:07 am
I've got another one that works...
Purchased on eBay for $8.49 shipped...
This seller has the best prices and most reasonable shipping on these suction cup mounts. (Some are charging $12 for shipping... Mad )
http://search.ebay.com/search/search.dll?sofocus=bs&sbrftog=1&dfsp=32&satitle=suction+mount&sacat=-1%26catref%3DC6&sabfmts=1&ftrt=1&ftrv=1&saprclo=&saprchi=&seller=1&sass=rarey57&fsop=32%26fsoo%3D2&coaction=compare&copagenum=1&coentrypage=search&fgtp=
b18c_ej8
b18c_ej8 Sat Apr 12, 2008 3:12 am
On another note, I've actually got two more of these particular mounts. One is for the camcorder mount on the top of the dash, and the other is the mount for an outside-type bullet cam, and they hold extremely well.
I do think that if you're going to use a suction mount on the windshield, the TunerView is a bit heavier than the satellite radios they're designed to hold up.
They'd probably work a bit better & not bounce around so much if you rest the TunerView on the dash (or otherwise support it from the bottom) and use the suction cup to keep it all in place.
Just my two pennies. Smile
b18c_ej8
HRTuning Sat Apr 12, 2008 3:20 am
Makes sense. Thanks for the find!
b18c_ej8 Sun Apr 13, 2008 2:47 pm
My monstrosity... LOL
Used the bracket above, but removed the suction cup for a future project.
Through-bolted the "stem" of the mount behind the cupholder, and used the swivel mount to adjust the tunerview.
Looks like ass but the ugliness isn't seen when installed. Smile
b18c_ej8
HRTuning Sun Apr 13, 2008 4:28 pm
Good spot for it. You may want to angle it your way a bit if you can.
b18c_ej8 Sun Apr 13, 2008 5:29 pm
It's installed now, and it actually isn't too bad as it sits.
But retaining the swivel on the mount will provide some flexibility if need be.
b18c_ej8
HRTuning Sun Apr 13, 2008 5:48 pm
Very nice. Smile
muasboi Mon Apr 14, 2008 3:58 am
b18c_ej8 wrote:
so by doing this you can't remove it easily to prevent theft then huh? assuming this is a daily driven car. j/c. because i was gonna get a tunerview too, but just velcro it to my dash, and remove it often.
muasboi
HRTuning Mon Apr 14, 2008 4:59 am
It's fine to use velcro.
TurboGSR96 Mon Apr 14, 2008 2:22 pm
IMO I like to leave stuff like this loose in the car so that if a thief decides to hit my car, hopefully he will just take the tunerview and be happy with it, I would rather him be able to grab it easily then rip my whole car apart trying to get it, same with my headunit, it can be pulled right out, no prying on my dash to get it out.
1996 DC2 T67HO
585whp
385wtq @21-23psi E85
11.01 @ 137 16psi creeping to 21psi RTP Powered
TurboGSR96
b18c_ej8 Mon Apr 14, 2008 5:10 pm
Definitely understandable, but I really don't have to worry about things like that around here. Upstate/Central NY isn't exactly a high-crime area.
Car is garaged 95% of the time, and alarmed 100% of the time I'm not around. (Viper 2way, stealth-install)
I don't drive it very often, and if I'm going into the "city", I take one of the Accords (Mine or my wife's).
The problem I have with semi-permanent installs is that they tend to move/bounce around...
I had a deck that was easily removable, and it would slide out when I launched hard or downshifted to speed up.. Laughing
b18c_ej8
HRTuning Mon Apr 14, 2008 9:15 pm
I had that problem too haha. Oh, memories.
TurboGSR96 Tue Apr 15, 2008 2:16 am
How did you mount that to the TV? did you take apart the case and run the bolts through the holes from the inside out?
1996 DC2 T67HO
585whp
TurboGSR96
HRTuning Tue Apr 15, 2008 2:42 am
You have to take it apart to do so, yes.
