TunerView Pre-Release Software
HRTuning Wed Mar 26, 2008 10:11 pm
The software is available on the website. Very simple layout, easy to use. If anyone has any comments or suggestions please let me know. The first version of the firmware does not include some of the most advanced features that will be released. This is basically to make sure everyone has no troubles with the unit, so I'm keeping the first release simple. Smile
http://www.hrtuning.com/software/
franniestopdat Thu Mar 27, 2008 1:08 am
the program is very laggy on computer. there is a five second delay on everything i click on. sometimes it just freezes for awhile and is unresponsive.
franniestopdat
HRTuning Thu Mar 27, 2008 1:12 am
What are you running? Is it trying to connect? (The connect button would say "Connecting")
franniestopdat Thu Mar 27, 2008 1:21 am
no i don't even have the TunerView. i'm just messing around with the program. I'm running Windows XP. The connect button just says "connect". Where can I order the TunerView once it's released by the way? I'm going to order it the first day it's available.
franniestopdat
HRTuning Thu Mar 27, 2008 1:24 am
Right, but the auto-connect tries to connect on all ports to see if a TunerView is present. The auto-connect is the only thing that would be doing anything. Otherwise, there's absolutely nothing going on to cause that.
They'll be available on the store starting next week and there will be an announcement here.
sohc_mshue Thu Mar 27, 2008 7:28 am
it seems to be running real slow on mine too for whatever reason.
www.shuetuning.com
sohc_mshue
HRTuning Thu Mar 27, 2008 9:12 am
Not sure I understand what can be running slow. The software isn't doing anything, it's just an interface. I also have XP and it runs as expected.
b18c_ej8 Thu Mar 27, 2008 1:09 pm
Badass!! I installed it here on my work PC (XP), and I don't have any lag. I didn't press "connect" though since there's nothing to connect to...
Other than that, it looks really good. Seems to be very easy to set up.
So basically you'd load the software, set up the dropdowns how you want, then press "program" and it saves your settings to the TunerView?
b18c_ej8
sohc_mshue Thu Mar 27, 2008 1:54 pm
HRTuning wrote:Not sure I understand what can be running slow. The software isn't doing anything, it's just an interface. I also have XP and it runs as expected.
basically as soon as i open it up it goes into that program not responding mode for a minute and then if i try clicking on something it does it again. I opened neptune at the same time as the tunerview software and it opened fine. Although my computer could just need a restart.
edit: restart didn't help
www.shuetuning.com
sohc_mshue
Turbogixxer Thu Mar 27, 2008 3:27 pm
Zero problems here. Smile
Turbogixxer
HRTuning Thu Mar 27, 2008 3:37 pm
b18c_ej8 wrote:Badass!! I installed it here on my work PC (XP), and I don't have any lag. I didn't press "connect" though since there's nothing to connect to...
When it connects to the TunerView it shows the current setup on the TunerView. You can save and load configurations for easy setup. So if you want a different configuration, once the TunerView is connected you manually change the setup and hit program or select Load from the file menu, choose your lcd file, and then hit program. If you hit read it will show you what's currently on the TunerView again. Very easy to work with.
Well, the auto-connect code is the same as NepTune's, so there shouldn't be any lag. It's possible that it was a bad build. I'll try to put another up later today and see if that helps anyone.
Cjperformance Thu Mar 27, 2008 3:39 pm
none here
Cjperformance
TurboGSR96 Thu Mar 27, 2008 5:58 pm
Nice! works fine for me, and I always have problems.... Very Happy
1996 DC2 T67HO
585whp
385wtq @21-23psi E85
11.01 @ 137 16psi creeping to 21psi RTP Powered
TurboGSR96
HRTuning Thu Mar 27, 2008 7:03 pm
hehe Razz
tepid1 Thu Mar 27, 2008 7:53 pm
Works for me too.... no lag at all. Wink
I would recommend a "preview" layout type viewing window so you can see what it will look like before you update the tuner view. Just my opinion though.
2000 Integra GSR SFWD/TS 850+whp monster
Running a MoTeC M4 now.... but still tuning NepTune Wink
tepid1
Announcements
