Fuel flow
Fuel flow
jmeyer99 Thu Mar 15, 2007 8:22 pm
Is it possible to log fuel consumption? I would like to figure fuel mileage in conjunction with a GPS.
Pintle-regulated Venturi Induction
www.prvperformance.com
jmeyer99
    Send private message View user's profile Send e-mail Visit poster's website
HRTuning Thu Mar 15, 2007 8:52 pm
Unfortunately not. Best way to do that is to take the amount of miles driven and divide that by the fuel you put into the tank at next fill up.
Injector pulse
jmeyer99 Thu Mar 15, 2007 9:29 pm
...but can you get a relative fuel consumption rate from the injector pulse? Then tune for best relaative fuel consumption and, finally, do the fill up test.
jmeyer99
HRTuning Thu Mar 15, 2007 10:06 pm
No, there are too many outside variables that can effect the actual fuel delivery. Pump, injector size, fuel pressure, the regulator ratio, etc.
Constants
jmeyer99 Fri Mar 16, 2007 1:47 am
The listed items are constants day to day, particularly the fuel pressure since it is regulated. I am looking for a parameter to tune fuel economy, not the fuel economy itself. It seems the fuel economy is directly proportional, but not equal to, the injector pulse length times the number of injector pulses divided by the distance driven. If true, then if this parameter is optimized, the map will represent the best fuel economy. Is this correct and can I log the pulse length and number of pulses in real time?
Distance can be accurately measured with GPS.
jmeyer99
HRTuning Fri Mar 16, 2007 4:17 am
You can't actually tune based on injector pulse and hope it magically works out. You have to watch a wideband at which point watching the injector pulse wouldn't do you any good. Just tune with the wideband for fuel efficiency or economy, whichever you're hoping to achieve.
jmeyer99 Fri Mar 16, 2007 6:52 pm
How would you street tune a pintle-regulated Venturi?
jmeyer99
HRTuning Fri Mar 16, 2007 7:55 pm
The same way I'd tune any other setup.
NepTune Logger
