Feature Request Discussion.
HRTuning Tue Apr 17, 2018 8:28 pm
You have access to low cam cut and restart.
You can adjust the fuel maps while in percentage view, I believe.
strath Wed Apr 18, 2018 5:59 am
HRTuning wrote:You have access to low cam cut and restart.
Fuel maps cannot be adjusted while in % view, just checked. And I thought low cam cut and restart was the deciding variable for the switch between high / lowcam. Not the cut and resume for two step. Or am I mistaken?
All true street kings come from Tucson Wink
strath
HRTuning Wed Apr 18, 2018 2:37 pm
You're mistaken on both accounts.
They surely can.
And low cam cut/restart is the cut and restart for low cam, as named.
VTEC settings have the crossover settings, not rev limits.
More "sensor adjustment inputs"
robom2013 Thu Apr 19, 2018 2:57 am
With 81 pages of "feature requests" I hope this gets reviewed...
Why don't we have more than 1 analog input for sensor adjustments??? I don't see why we only have to be limited to one.
robom2013
Re: More "sensor adjustment inputs"
Relic1 Thu Apr 19, 2018 3:58 pm
robom2013 wrote:With 81 pages of "feature requests" I hope this gets reviewed...
with "HRTuning" responding to almost everyone of the posts, obviously he's on top of it.
Relic1
HRTuning Thu Apr 19, 2018 5:00 pm
Space.
Coupe-r Mon Apr 30, 2018 8:50 am
can we have value adjustments for 2 step cut and resume?
meaning can we adjust HOW hard/soft the ignition cut is on 2 step. Most people run a variable rpm 2step by TPS % (low and high cam restart won't help here)
Also the ability to modify the fuel values while viewing through the difference % screen would be amazingly helpful.
ONLY through using the adjust icons (not on the right click menu like in the table view) but yes technically you can adjust cells in % view (using the icons only)
No takers on Injection timing adjustments?
HRTuning Mon Apr 30, 2018 11:23 pm
Not for the adjustable. As you'll notice a lot of that has to do with the engine itself anyway. Nobody wants a slow cut.
This works just fine with the quick keys as well.
Coupe-r Tue May 01, 2018 12:23 am
Nah if anything a quicker, MORE aggressive one would be good. (for the boost building guys this would help)
It has a lot to do with cam profile, exhaust temp (fuel and ignition) but also HOW quickly it cuts/how it cycles the cut.
Do you think injector timing would be a possible feature to add (like Hondata has)
Coupe-r Tue May 01, 2018 12:24 am
delete
delete
delete
Coupe-r Tue May 01, 2018 12:27 am
delete
HRTuning Tue May 01, 2018 4:20 pm
There's no gap between cut and restart when using that feature, so it can't get more aggressive.
AKindinos Thu May 03, 2018 5:14 pm
will it be possible to add and remove rows & columns in between the scaling? adding to the end end then transferring the complete map is a bit of a hustle when you are on the dyno
AKindinos
