New ECU with Neptune
Txdragon Wed Jul 17, 2019 2:07 pm
Been a while since I've needed assistance but, here we go!! Ok so, I've been running a P06 VTEC converted ECU with Neptune. The ECU has gone bad so I had to order another. I ordered a P28 and wondering if I may have to change that in the Neptune software; P06 to P28, or if it really matters since there is a tune already on it. I **think** it would only matter for base map loading, not sure. Maybe options to disable like Knock sensor, etc? Anyhow, does it make a difference?
Txdragon
HRTuning Wed Jul 17, 2019 6:26 pm
Not at all, that just enables certain options in the basemap which you can manually do as needed!
Txdragon Wed Jul 17, 2019 9:43 pm
Thanks much!
Txdragon
HRTuning Thu Jul 18, 2019 3:44 pm
No problem
Txdragon Thu Jul 25, 2019 1:25 pm
Have replaced the ECU and the trouble I had is no more! What I DO have is a really rich AFR across the map now. I have narrowed 2 possible reasons why but, I'm no expert.. Reason 1 is that the P06 was having some voltage issues I was fighting against to seal the tune, or 2, there is a notable difference between the P06 and P28 that mattered after the fact of replacement. Hoping to drum up some kind of explanation on this, my next request would go to HAmotorsports.
Txdragon
HRTuning Thu Jul 25, 2019 3:45 pm
1 is very likely! You may be able to just use the overall fuel trim if it was a voltage issue. It should equate to a percentage that works across the board.
Txdragon Thu Jul 25, 2019 6:03 pm
HRTuning wrote:1 is very likely! You may be able to just use the overall fuel trim if it was a voltage issue. It should equate to a percentage that works across the board.
Thanks for the input. I believe what caused the whole frackus was a dead cell in my battery. It was reading positive voltage from ground. I chased this freaking rabbit for 3 weeks trying to find what I thought was a bare wire touching chassis.. Sigh.. This, in turn, I feel frizzled the ECU, prompting replacement.
Had to recalibrate Neptune and my WBO2; offsets needed adjustment. Got them near on par again, +/- .3 difference.
Only big headache right now that I feel is tune related is my idle AFR. Goes lean occasionally then levels out, rinse and repeat. After operating temps, it fluctuates less aggressively.
Txdragon
HRTuning Thu Jul 25, 2019 7:34 pm
You can see in map trace if it's stable in an area or moving around due to fluctuations.
If it's in closed loop swinging change the temperature for CL operation.
Txdragon Fri Jul 26, 2019 11:24 pm
HRTuning wrote:You can see in map trace if it's stable in an area or moving around due to fluctuations.
It's in open loop. Odd part is this tune was set for about a year. I thought maybe injector dead times (due to voltage fluctuations) and whatnot but... Something to do with that maybe? I dunno. Still have to OHM them out to see if they're within spec. If for any reason my injectors decided to go fun up, they're still replaceable under warranty.
Txdragon
HRTuning Sat Jul 27, 2019 4:31 pm
That could definitely be part of it.
