Target AFR Table issue
MLSD Mon Jul 15, 2019 11:26 pm
Hello all I'm wondering if anyone has experienced this issue before. I've just set up my afr table with my desired target ratios and then recorded a data log. Once I'm ready to make adjustments to my fuel maps I open the arf table to make sure all is well but the values within my table have drastically changed. I thought at first I may have not set up the fuel value correctly however this isn't the case (I am using lamba as my unit of measurement) . My wideband is set up correctly and has been logging just fine. But every time I open the target AFR Table in reference to the changes I want to make, the values on the afr table have changed. Any help is appreciated.
MLSD
HRTuning Tue Jul 16, 2019 4:08 pm
You only need to set target AFR once in order to use it with the lambda overlay percentage difference, etc. It is low resolution, so values may get rounded.
