Neptune Freezes when VTEC engages
ZCHondaCRX91 Fri Mar 08, 2019 6:54 pm
What is happening is as soon as VTEC engages, neptune freezes (unresponsive) while datalogging. Then I gotta close and reopen the neptune software to reconnect to the ECU.
I've used this ECU/Demon in a previous car (was non-vtec). Then I put it in my Accord and used it to tune a F22B1 (half VTEC), and I never had any issues datalogging with that VTEC setup. I just installed a H23A Bluetop with the stock F22B1 wire harness, and this is the setup that is giving me this issue. For this reason I don't think it is anything in the ECU or the wiring harness (since it worked fine before). I was curious your opinion on what could be causing this? Any setting in the software I could change?
I tried disabling VTEC and it datalogged fine, but for some reason when VTEC engages, Neptune freezes up.
Thank you!
ZCHondaCRX91
HRTuning Fri Mar 08, 2019 9:35 pm
If the software releases if you unplug the USB, instead of quitting the app, that would be a quick indication that you have some serious noise issues that are causing USB communication failures.
