TunerView RD1 vs TunerView App
terravista Mon Feb 25, 2019 10:16 pm
I just realized after installing the dashboard in a race car that the roll cage dash bar is going to prevent me from installing a conventional gauge cluster back in its original spot.
My initial thought was, no problem, I can just install a RD1 and get the clearance I need and replace the cluster with the race dash.
After some reading, it looks like that I cant use the RD1 and TunerView app at same time because there is only one port on the DemonII, which is currently being used by the bluetooth adapter.
So i was thinking, I could ditch my plan to use a tablet in the din slot in the center console and just install the tablet where the cluster is.
So my question is, is there any reason why I shouldn't? Besides the fact that I cant use the trick software to fully customize the RD1, and some of the peak/recall functions, can the tunerview app on a tablet essentially take place of an RD1?
Also, with the fuel level adapter, couldn't I just add fuel level as an analog gauge in the Tunerview app? or would that only work on RD1?
I just want to make sure I wouldn't miss out on any crucial functionality, I dont need an odometer or trip setting, but fuel level would be important.
Much appreciated!
terravista
HRTuning Tue Feb 26, 2019 6:12 pm
You should be able to use the TunerView app as a cluster and one of the layouts does have peak and min values on it. The ECU analog inputs can be programmed as well.
