Map sensor is reading max psi when trying to start the car
krazy4 Fri Nov 16, 2018 8:16 pm
Hi guys just started having an issue with the car.
I've replicated this with the omni power 4 bar map and the stock honda 1.75 bar map.
When going to start the car, the datalogger shows 46.3psi with the 4 bar map.
It should show negative when starting the car.
Swapped out to the stock honda map and it reads 11.2psi when starting the car.
As you can guess the car doesnt start or if it does it runs really bad.
Any ideas?
EG sedan - S366 turbo H23a w/ GSR trans
367whp on 9.5LBS - higher boost coming soon
krazy4
HRTuning Fri Nov 16, 2018 9:15 pm
Check the input voltage both in the software and actual, this is hardware issue.
