Anti-theft help
Anti-theft help
8400rpm Thu Jun 21, 2018 8:28 am
Good day. I would kindly like some help on how to set up anti theft for the first time.
I would like to press the throttle 3 times in order to start vehicle. Ive tried entering 3 into the first row ie: tps 3, brake 0, tps 0 with advanced anti theft enabled.
The car does not fire up even though i press throttle 3 times while ignition is on.
What am i doing wrong?
Do i need to enter an input in one of the three 'required input' tabs or can i leave it at 'none' and just use the tps setting alone.
My car does not have the brake switch wired to ecu. If it is compulsory to enter a 'required input', which one do you suggest?
8400rpm
HRTuning Thu Jun 21, 2018 8:14 pm
You can see Anti-Theft as an item in the datalist while datalogging to verify you're properly meeting criteria. The additional input is for a switch if you want to wire one up.
8400rpm Sun Jun 24, 2018 3:59 am
Ok so i viewed item as on/off light.
It shows as anti theft 'on' (ign is on). It then reads the 3 tps pushes then changes to 'off', but as soon as i crank, the light changes to 'on' again and car does not start.
Perhaps have any insight on this?
8400rpm
HRTuning Sun Jun 24, 2018 9:01 pm
That would suggest your ECU is resetting during cranking, so you have an external issue to track down, if all other data is still updating in real-time.
