Selecting type of fuel issue
Damontoole Wed Jun 06, 2018 4:18 pm
Having an issue with my o2 out put I try and select 14.7 I push ok, seems like it defaults to.8769 every time I try selecting the type of fuel It doesn't stay on what I'm selecting. I never encountered this issue before it's always worked as it should. Any ideas?
Damontoole
HRTuning Wed Jun 06, 2018 7:52 pm
It works, if you have your decimal point set to a decimal point.
Damontoole Wed Jun 06, 2018 8:07 pm
How do I change it back to afr's instead of voltage display then? Thanks for your help
Damontoole
HRTuning Wed Jun 06, 2018 8:08 pm
It's not voltage for fuel type, so what are you actually changing?
Damontoole Wed Jun 06, 2018 10:41 pm
I didn't think it was but every time I select 14.7 with fuel additive it is automatically changing into a decimal point that's very small
Then makes all the numbers transfer to decimal points also while logging not getting a real afr Reading just everything's in decimal points with a whole number as zero.
Damontoole
HRTuning Thu Jun 07, 2018 12:33 pm
Change your currency setting to a decimal point. I mentioned this above already.
Damontoole Thu Jun 07, 2018 3:48 pm
[img][/img]
Every time I change it the setting doesn't stay it automatically changes back when I close the window little frustrating.
Only thing I can think of next is resetting my demon
Damontoole
HRTuning Thu Jun 07, 2018 6:02 pm
Preferences for the application have nothing to do with the Demon. Feel free to delete the Prefs file and start the app settings from scratch.
Damontoole Thu Jun 07, 2018 6:11 pm
Ok thanks
Damontoole
