On-board datalogging with switch issues
Irkar Tue Feb 06, 2018 1:02 am
I have the input set for on-board to D4 scs for activation
the same for deactivation but inverted.
The scs getting a ground would activate and losing the ground should turn it off I'm assuming?
All of the threshold values are at 0 and both are set to "or".
Well it seems to be logging a ton of sessions for no reason when it should only be two 4-5 minute sessions. By ton I mean 4500 sessions!!!
It was working well with just the thresholds but would rather a switch. I chose scs because it was convenient due to being wired already and I don't need it for it's intended purposes.
I also set the service connector input in extras to none to prevent it thinking that I wanted to check for codes.
Irkar
HRTuning Tue Feb 06, 2018 1:34 am
OR means the switch or thresholds.
Don't forget to also change what the SCS does in the parameters.
Irkar Tue Feb 06, 2018 3:28 am
I didn't realize that you can't eliminate the thresholds completely by leaving them all zeros and use switch only.
Also made sure SCS was set to none in Parameters-extras
I set them both to AND
Left activate all at 0 So I can activate at any time.
Changed deactivate to below 5000rpm, below 70 MPH, and below 20% TPS so I could still deactivate at hwy speeds with the switch.
Seems to work properly now
Thanks HRTuning!
Irkar
HRTuning Tue Feb 06, 2018 3:43 am
No problem!
Coupe-r Sun May 20, 2018 8:38 am
I was having issues also where it would either log loads of small sessions, or just not deactivate.
Now I think what I need to do is set the input to inverted for deactivate?
ACTIVE =ACS
2500
45kph
DEACTIVEATE
=ACS
2000
40kph
(Does the above need an invert on the ACS for deactivate?) silly mistake by me hah.
HRTuning Sun May 20, 2018 3:48 pm
Definitely invert for OFF if using ACS switch as ON.
