Honda OBD2 non-adjustable distributor, how to adjust timing?
ZCHondaCRX91 Fri Sep 01, 2017 9:18 pm
I have a 1996 Accord with F22B1, and it has the non-adjustable distributor (can't adjust ignition timing). I converted to OBD1 and I'm using a P06 with moates demon. How can I sync the ignition timing when rotating the distributor does nothing? Thank you.
ZCHondaCRX91
HRTuning Fri Sep 01, 2017 9:44 pm
Time it with the software locked to 16.5 degrees, then enter the actual ignition timing measurement into the base timing setting in preferences. i.e. if you're at 14 instead of the 16 requested enter 14 in the base timing setting.
ZCHondaCRX91 Fri Sep 01, 2017 10:08 pm
Thank you I will give that a try.
ZCHondaCRX91
HRTuning Fri Sep 01, 2017 10:23 pm
No problem
