Llcfabrications Sun Sep 11, 2016 8:54 pm
Yes it's set for hondata, it use to work fine after you guys repaired the led in the screen awhile back,
It has the same pin outs the cable came with the screen when it was originally purchased and they match but the ground wire which is black I assume is exposed as if the wire insulation has come off but the other wires are still oem
And I'm not sure if the interface has a green light I have it mounted under my dash but I will check. Where is the green light visible from?
