Idle problem after ECU reset
whitewidow Wed Mar 23, 2016 9:59 pm
Hi, the other day i was adjusting my tps so i did a ecu reset, after that my idle stay at 1600 no matter what.
I did a demon reset, put the a base map and nothing.
When i disconnect the iac valve the rpm drop to 1300 so i assume that's not the problem, the fast idle valve has zero to minor suction.
I also did another ecu reset then stay at 3000 rpm for 3 min then idle (1600) for 3 min and nothing change.
I dont know what to do Sad
whitewidow
HRTuning Wed Mar 23, 2016 10:18 pm
I don't know what you mean by ECU reset.
You should be able to adjust the IACV duty slider and the idle should change. If you can't do that you're in limp mode or you have a hardware issue/vacuum leak.
whitewidow Wed Mar 23, 2016 10:53 pm
HRTuning wrote:I don't know what you mean by ECU reset.
Pull out the 7.5 back up ecu fuse.
At 0% IACV duty is 1500 rpm
At -100% IACV duty is 1300 rpm
the idle change when i move the duty slider but is the idle is still too high.
whitewidow
HRTuning Wed Mar 23, 2016 11:00 pm
So you still have an IACV hardware issue or vacuum leak. Pulling a fuse can't cause that.
whitewidow Wed Mar 23, 2016 11:05 pm
HRTuning wrote:So you still have an IACV hardware issue or vacuum leak. Pulling a fuse can't cause that.
The things is before i did that my idle was just fine at 900+- rpm
whitewidow
HRTuning Wed Mar 23, 2016 11:14 pm
And that's fine, but doesn't detract from the reason it's happening now. You're either actually in limp mode or you have one of the two things stated working against you.
whitewidow Sun Mar 27, 2016 7:44 pm
[quote="HRTuning"]And that's fine, but doesn't detract from the reason it's happening now. You're either actually in limp mode or you have one of the two things stated working against you.[/quote
I found the problem, i miss adjust the tps at CT Embarassed
Thanks for the help!
whitewidow
HRTuning Sun Mar 27, 2016 8:01 pm
That can also do it!
