b16a1 with ITR cams, use oem/stock cam gear or Adjustable ?
gabrielsousa Mon Dec 21, 2015 3:54 pm
b16a1 with ITR cams, use oem/stock cam gear or Adjustable Cam Gears ?
opinions ?
gabrielsousa
Cam geat
awadkhan Fri Jan 29, 2016 8:22 am
It would be better to put adjustable cam gears and adjust for the shorter deck height
awadkhan
gabrielsousa Tue Feb 02, 2016 10:20 pm
will give this readings on crankshaft ? with stock cam gear ?
intake vtec lobe
open - 15 before TDC
close - 45 after BDC
exhaust vtec lobe
open - 45 before BDC
close - 10 after TDC
gabrielsousa
NepTune'd
