RD-1 problem communicating
MadLor Sun Sep 06, 2015 7:40 pm
So my RD-1 is connected to my Ep3 & krpo. it turns on fine. The issue I have is that for some odd reason I can't get the RD-1 to show any values. For example I have my rpm template but no numbers will show. At one point however it did read the rpm but now it doesn't. I would say it will only read it less than 5% of the time. Another issue is that when I make a template and save it then press program it still does not load onto my device. Any tips tnx. Lastly I have a hondata 4 bar map but can't find that option on the drop down menu.
MadLor
MadLor Tue Sep 08, 2015 10:51 pm
Ok now it's working again.
Would anyone know how to set up an EGT gauge?
MadLor
MadLor Tue Sep 08, 2015 11:10 pm
Need help trying to set up oil pressure, fuel pressure gauge as well
MadLor
HRTuning Wed Sep 09, 2015 1:09 am
I believe ELD is the only input we're currently taking in for K-Pro. You can set that up on the sensor page.
MadLor Tue Sep 15, 2015 9:36 pm
Ok so I'm still having problems with my RD-1. When I turn on the car, unit turns on every time with the appropriate template. The problem is that it rarely works in terms of the rpm, boost, AFR etc showing any values. Sometimes it works but the most longest I've seen it work is about 1 min. Once I leave the garage it won't read again.
Pls help.
MadLor
HRTuning Tue Sep 15, 2015 11:15 pm
You likely didn't connect it to a switched ignition source or your wiring is loose. If the box doesn't keep power after key on you won't get any data.
MadLor Wed Sep 16, 2015 7:23 am
Wiring is soldered but let me check if it is wired correctly
Tnx
MadLor
MadLor Wed Sep 16, 2015 10:40 am
Tnx
MadLor
HRTuning Wed Sep 16, 2015 1:06 pm
It must maintain power after key on, even through cranking. Switched ignition source only.
MadLor Wed Sep 16, 2015 10:16 pm
Ok it was on a switched ignition source along with one of the wires from the kpro module. I switched to an switched ignition source coming from the cigarette lighter. On this same wire though I have a wire connected to a relay for my push start button. Is that ok?
MadLor
HRTuning Wed Sep 16, 2015 10:56 pm
I do not know how your third party products may interfere with the device.
MadLor Thu Sep 17, 2015 2:12 am
I see. How do I get my boost gauge to display psi instead of MB?
MadLor
HRTuning Thu Sep 17, 2015 4:37 am
If you're talking about the NepTune software that's in preferences.
MadLor Tue Sep 22, 2015 6:56 am
ok cool found it.
Does the kpro module also have to be connected to a switched ignition source?
MadLor
HRTuning Tue Sep 22, 2015 1:09 pm
Yes, it does.
