wideband direct serial logging issue
maurice Tue May 05, 2015 1:22 pm
Hi!
I have a problem with my direct serial logging.
I know its not specific neptune related but maybe you have some good advice/input Smile
I have a new laptop but it has no serial connector, so i bought an usb serial converter, Ive setup the baud rate etc in the system on the com port for my innovate lc-2.
The problem is i can start direct serial logging and works fine, BUT after a while the values of afr just freeze! Sometimes it takes 10 min before it freeze, sometimes 5 mins some even shorter and thats really annoying..
When in neptune i stop direct serial logging and connect again then it works for a min then freezes again Sad
Its the same in log-works.
Tried innovates support forum.. but its down??
What can cause this issue?
maurice
HRTuning Tue May 05, 2015 2:33 pm
If it also happens in logworks than the converter or the drivers for the converter are the issue. You may want to try a different converter.
maurice Tue May 05, 2015 3:19 pm
Thanks for the fast reply! Smile
Oh i for got to tell i already tried a different usb converter, but same result.
Hmm i saw there is a new firmware update available for the lc2 i could try that.
Could it be the lc-2 controller itself? That it times out or something..
I have an analog gauge wich works flawless.. Guess its something with the serial protocol.
After that i Probably have to mail innovate.
maurice
HRTuning Tue May 05, 2015 3:26 pm
If you're not using a power inverter then I have no other suggestions.
maurice Tue May 05, 2015 9:14 pm
What do you mean with a power inverter?
maurice
HRTuning Tue May 05, 2015 10:55 pm
To power the laptop while in the car.
maurice Wed May 06, 2015 8:03 am
Ahh lol! in that way.
No im not using a power inverter in.
Thanks for your input
maurice
HRTuning Wed May 06, 2015 1:07 pm
That was my only thought for something that produces a lot of noise.
