Displaying wideband on Tunerview II
civic si Sun Feb 15, 2015 7:16 pm
I have a PLX SM-AFR wide band and would like to display the AFR on my Tunerview II. Which input would be best on the ECU for this?
civic si
HRTuning Sun Feb 15, 2015 7:37 pm
Any of the available inputs can be used for this. Choose the one that suits you best. You'll find all available inputs on the Sensors page of the TunerView software. You did not mention if you're on the chip or NepTune RTP, so you'll need to refer to the sensors page in the TunerView software.
civic si Sun Feb 15, 2015 7:51 pm
Sorry should have put that in there, I have chip based Neptune. I see the 4 inputs on the sensors page, and will choose one.
I also have an Autometer 4590 0-100 pressure sensor, can that be put into one of those inputs also to display my oil pressure?
civic si
HRTuning Sun Feb 15, 2015 9:40 pm
Any 0-5v sensor can be used.
civic si Sat Mar 28, 2015 2:00 pm
I finally finished installin my wideband and Auto Meter 2246 sensor. I had the wrong part # in a previous post.
The wideband I connected to the O2 port and it seems to be working perfectly.
I want to make sure that I have my oil pressure sensor setup right. Since I did not get the sensor new I do not have and cannot find documentation on that sensor. Do you happen to know if the voltages read as standard (0 volts 0 pressure) or reversed (5 volts 0 pressure)? any help would be appreciated.
civic si
HRTuning Sat Mar 28, 2015 3:23 pm
Awesome about the wideband.
You'll need to find the manufacturer documentation for the other.
