question from a french "beginner" with Neptune sof
HRTuning Tue Jun 05, 2018 3:24 am
No problem
seven40 Sun Mar 17, 2019 8:26 am
Hello everybody! Very Happy
Since a long time that i haven't give any news , i just come here to tell that everything is working great with NepTune, i'm still happy of the software and alos of the Demon II .
I hope that this year i will find the time to try to run with ethanol , i'll let you know if i reach my goal or not Cool
seven40
HRTuning Tue Mar 19, 2019 6:28 pm
Excellent!
seven40 Sat Jun 01, 2019 12:32 pm
Hello everybody!
I have a question about the "on board logging" capability.
I have connected a switch on the SCS connector ( D4) and tested it , it ground correctly.
In the window "on board logging" , i have checked : "enable on board logging" , selected D4 for the activation input , then selected "AND" and the thresholds are all to zero.
For the desactivation input, i have selected "D4" , "inverted input" , "AND" and the thresholds are all to zero.
In the "EXTRA" window, i have setted "service connector input" to "none" : is it good or do i have to select another service connector input instead of D4?
As you guess, i have tried and it Don't work, i'm sure i misunderstood Something so i need some help please Embarassed
Thanks a lot for your answers! Very Happy
seven40
HRTuning Sat Jun 01, 2019 6:41 pm
If you ground it and it turns on in the software you can use it. Make sure your thresholds are actual values that are actually met.
seven40 Sun Jun 02, 2019 7:23 pm
Thanks a lot for your answer! Very Happy
About the thresholds, they are all setted to zero, as i want to activate and desactivate only with the switch.
In the "on board logging" window, i have checked "enable on board logging", i suppose there's Nothing else to do?
The switch grounds correctly and if i leave "service connector input" on D4 in the "extra" menu , the MIL appears on my Dashboard, so i'm sure that the wiring and the switch are ok.
If i put "service connector input" on "none" Inside the "extra" menu, it doesn't work. If i ground it, Nothing turns on into the software.
I'm pretty sure that i'm mising Something, i going to triple check all that, but i cannot do that until next weekend.
I'll let you know if i find the solution, i'm sure it is something simple i've missed Embarassed
Thanks for your help!
seven40
HRTuning Mon Jun 03, 2019 3:17 pm
If you're going to use AND then all conditions must be met, which they're currently not. Setup real values.
