question from a french "beginner" with Neptune sof
seven40 Sat Dec 31, 2016 8:04 am
Hi everybody, since a long time i didn't gave any news, but everything is working great Very Happy
I didn't find the time to work more on my map, as Something very sad happened to me this summer Crying or Very sad
What i can say about the Strange spikes is that i saw that sometimes my clutch was sleeping Under big load and when it was hot... but i knew that the clutch disc was in good condition, so after setting the clutch pedal, there's less "spikes"...
I'm not sure that these two problems are related, but for the moment i won't look closer as it is winter and working outside is a bit hard for me Embarassed Embarassed Embarassed
So actually i have another question, once again ( boring french... Rolling Eyes ) , there's Something i didn't understand about the software : what is exactly the " tip-in ignition correction" for ???
I uderstand that it remove ignition Under certain circumstance but why do whe need to remove ignition if we open throttle? Does it smooth the engine?
I know it surely sound stupid but i've done some research and didn't find any answer, i don't want to set Very Happy Very Happy Very Happy
Thanks for the answer and have a nice year end! Very Happy
seven40
HRTuning Sat Dec 31, 2016 1:10 pm
Slipping clutch is no good!
It smooths the transition when you press the pedal quickly.
seven40 Sun Jan 01, 2017 1:21 pm
Happy new year Very Happy
Thanks for the reply, i continue to study all the "nepTune" possibilities Laughing , thanks a lot!
seven40
HRTuning Sun Jan 01, 2017 2:57 pm
Happy New Year.
Lots of studying to be done!
Gandalf Wed Apr 19, 2017 1:26 pm
seven40 wrote:Hello!
Still no update by my side, still busy with my job Embarassed
Just have a question, in way to tune properly my engine ( now it is a H22A7, mounted in it's original car) , i am looking for a Knock gauge.
Do you know a good Knock gauge which can work with the OEM sensor?
If not, which gauge would you recommend to me?
Thanks a lot! Very Happy
I would recommend more than just a knock gauge, but rather, a knock system, the J&S Safeguard unit. It can retard ignition timing on individual cylinders, and other features. It can work with some oem sensors, and works very well with a Bosch flat (donut-style) knock sensor. John from J&S is very helpful too.
http://www.jandssafeguard.com/
Gandalf
seven40 Fri Apr 21, 2017 5:51 am
Thanks Gandalf for the input Very Happy
I didn't really decided yet which way i'm going to take, so i'll take a look at the J&S safeguard too Very Happy
seven40
seven40 Sun Aug 06, 2017 7:13 am
Hi guys!
Since a long time i haven't asked any stupid question, hehe! Laughing
I have tried to set up the "on board logging" function and i Wonder if i have to select the "autolog" to "on" if i want to record Something .
Said in another manner, what is the function of the "autolog on/off" button?
seven40
HRTuning Sun Aug 06, 2017 12:30 pm
Autologging in preferences is for the PC software to automatically datalog.
On board logging is setup in the ROM and on the device through the software. See the On Board Logging topic in NepTune Help in the Parameters section.
seven40 Sun Aug 06, 2017 2:08 pm
Thank you very much! Very Happy
seven40
HRTuning Sun Aug 06, 2017 4:38 pm
seven40 Sun Jun 03, 2018 11:32 am
Hello! Very Happy
Actually i'm experiencing a very Strange rev-cutting issue Crying or Very sad , some times, at high load, engine is hesitating and won't rev over 5500 rpm and i don't know why.
I don't have any error code and all the parameters seems correct so i don't know what to do.
I have recorded the problem with neptune so i have a .dlg file with the problem, so if somebody here can help me to diagnoze the problem, it will be great! Very Happy
Thanks a lot!
edit: a picture may help
seven40
HRTuning Sun Jun 03, 2018 11:29 pm
If it's a VTEC engine, you don't appear to be in VTEC.
seven40 Mon Jun 04, 2018 5:18 am
Thanks for your answer, it is an H22A7 engine and here's another picture of the parameters when the problem appears:
As you can see, the vtec light is not "on" but there's the "FCUT" light ( i suppose that it is the fuel cut) .
If i uderstand correctly, all the conditions are not yet met to engage vtec , so it is normal that vtec doesn't engage at this moment.
Do you suggest to modify the "low load value" ? Could it be the cause of the fuel cut?
Thanks a lot for your help! Very Happy
seven40
HRTuning Mon Jun 04, 2018 3:35 pm
So if your low rev limit for two step is less than your low load VTEC engagement you will hit the rev limit before you engage VTEC. I'm going to go out on a limb and say that's the case here.
seven40 Mon Jun 04, 2018 6:42 pm
Hello!
Thanks a lot for your answer! Very Happy
I think you are right, i'm going to do a test tomorrow and i'll let you know if it solve my problem, but once again, i think you have found the solution Very Happy
seven40
