question from a french "beginner" with Neptune sof
seven40 Wed Sep 24, 2014 3:30 pm
Hello!
First , i want to make apologies about my bad English, it's not easy for me to write in this language.
I'll try to be as clear as i can, if somebody don't understand what i want to say, please, don't hesitate to say that you don't understand and i'll try to explain if possible Embarassed Embarassed Embarassed
I just bouht a used "package" with a "demon" board and license number for Neptune.
I want to know if it's possible for me me to install and use Neptune with two different computers
Another question, does Neptune works on Windows 8 ?
Thanks a lot!
seven40
HRTuning Wed Sep 24, 2014 4:11 pm
There are no license numbers for NepTune. It's all automated.
It's not computer specific.
Windows 8 is fine. Smile
seven40 Thu Sep 25, 2014 5:06 am
Thank you for answering so quickly! Very Happy
seven40
HRTuning Thu Sep 25, 2014 1:43 pm
No problem. Smile
seven40 Fri Sep 26, 2014 5:09 pm
Hello!
Another stupid question :
I have a P28 ECU and i want to start to tune my engine with a B18 A/B basemap or a H23 basemap.
I'll prefer a b18 basemap because the bore of my motor is the same ( 81mm)... ... oh, i forgot to mention that i'm using a B20A7 from a prelude 3G that will be in the futur strongly modified.
I have searched throught internet and found nothing, i'm not "easy" with English and it' maybe why i didn't find my answer alone.
Does somebody know if there's one of these basemap available?
Thanks a lot and don't hesitate to tell me if i'm not clear Very Happy Very Happy
seven40
HRTuning Fri Sep 26, 2014 8:08 pm
File>New
seven40 Sat Sep 27, 2014 5:43 am
Once again, thanks for the answer Very Happy
I already looked in "File" and i found a lot of basemap Very Happy
But i forgot to mention that i'm looking for a NA basemap Embarassed Embarassed Embarassed
Maybe should i start with a non-vtec D series basemap , once again thanks for answering so quickly Very Happy Very Happy Very Happy
I'll show you the results as soon as possible!
seven40
HRTuning Sat Sep 27, 2014 1:22 pm
If you select RTP base you get to setup your sensors and choose the stock maps you want.
seven40 Sun Sep 28, 2014 5:28 am
Yes!
Very Happy
Once again, thanks a lot! Very Happy Very Happy Very Happy
seven40
HRTuning Sun Sep 28, 2014 1:23 pm
No problem. Smile
seven40 Sat Oct 25, 2014 7:38 am
Once again i have another "stupid" question.
It's about "harware" stuff but i don"t want to creat another message for that.
I've bought a used Demon v1.2, but a cable is missing Confused ,the one with the 4 pin female connector who have to be welded on the ECU.
It is that kind of cable:
http://www.ebay.fr/itm/2-X-15cm-4pin-Arduino-Jumper-Cables-Sensor-Shield-EQUIV-UK-SELLER-A-188-/221118879979?pt=UK_Computing_Other_Computing_Networking&hash=item337bb658eb
Could you tell me if this cable can replace the one missing? I also had to buy the female connector who had to be welded...
Or could you tell me where can i buy it?
Another question: can i tune my ECU without this cable? (i think i can not) I know it may sound stupid but i am really not aware about all that electronics stuff... Embarassed
Thanks a lot and forgive me if i'm hard to be undertanded, my English is very poor
seven40
HRTuning Sat Oct 25, 2014 1:30 pm
The 4 pin cable is necessary. Contact Moates if you need another one.
seven40 Sat Oct 25, 2014 2:46 pm
Thanks a lot! Very Happy
seven40
HRTuning Sat Oct 25, 2014 3:47 pm
seven40 Sun Nov 02, 2014 6:05 pm
Hello , once again it's me with ! Very Happy
I have a probem with my "demon", i''l try to be the more explicit as possible, but please don't forget that i'm using a foreign language Embarassed
And thanks a lot to answering me Very Happy
Now my demon is connected but i cannot use it.
First, i had a message : "unknown ECU", i do some research and i find that i didn"'t download correctly the basemap to the Demon.
Now, it's ok, i didn't have anymore this error message.
Actually, when i start the car, if i open the "gauges Windows", it open but all the gauges stays at "zero".
I can download the map that's Inside the Demon but if i do any change, it doesn't act on the car...
Also, if i open the "error code window", it opens correctly but there are no error codes while my MIL is blinking ( code 21 and 41, that is normal because i didn't have any o2 sensor and the vtec solenoide isn't connected)
I believe that the Demon and my ECU doesn't interract but i don't understand why.
I've looked at the installation video but my English is so bad that i only understand the half of what is explained Embarassed
Maybe it's an hardware problem, i'll try to verify the 4 pin cable again but maybe you have a idea of what the problem is?
Just want to had that the car rev until 6000 rpm whitout any problem or other error code.
Thanks a lot and forgive me for my question, i've done some researchs before asking there but wasn't able to find the answer Embarassed
seven40
