Correct wiring?
HRTuning Tue Sep 30, 2014 8:32 pm
Sweet.
If it's setup for NepTune RTP it should work. The TunerView forwards that data upon request.
Norlael Wed Oct 01, 2014 2:30 am
that would be those bin files from the google play shop then I suppose? lol ok makes sense I was trying to use the sample ones Embarassed
Norlael
HRTuning Wed Oct 01, 2014 2:35 am
I imagine those are sample datalogs.
I'm referring to purchasing the NepTune RTP protocol and selecting it in the protocols section.
Norlael Mon Oct 06, 2014 7:10 pm
ok sooo close to full functioning system... got all of the modules interfacing, have the BT connecting to my tablet, now when I start a new log it opens then shuts immediately. 2 options came up neptune and neptune rtp, I only tried the rtp one gonna try out neptune and see if it does the same.
Norlael
Norlael Mon Oct 06, 2014 7:15 pm
ok more detailed info. when I select honda or rtp in the protocol it does the same thing, logs for about 15 seconds and quits. the display shows all the wrong info, also. such as 36mph while not moving 215 deg when cold etc...
could the whole cause of this be a crossed over txo rxo wire?
Norlael
Norlael Mon Oct 06, 2014 7:38 pm
nvm I switched those 2 back and forth and still same thing...
keep getting a solid green light on BT module and solid red.
Norlael
HRTuning Mon Oct 06, 2014 8:09 pm
You have it hooked up to the daisy port? Have you tried using the RD1 software over the Bluetooth COM port to read the programming and make sure it communicates correctly?
I can't help you with the BT module, as I don't make it. You'll need to email Moates for that portion.
If you don't have the additional analog inputs enabled for logging you may want to try that. The app may expect that extra data.
If the same thing happens when you switch the rxi and txo then there's likely another issue.
If none of that clears it up for questions about the Android app specifically you can email Peter @ HRTuning.com
