TUNER VIEW II w/s300
chickenbandit Thu Aug 21, 2014 6:22 pm
I've recently switched from a working neptune demon with tuner view II to hondata s300 with the tunerview II.
I'm assuming that im not getting a signal from my interface that I bought for the s300 to tunerview.
I've checked the following things: inside the tuner view i have s300 enabled, on the side of the tuner view the wires are plugged into the middle port, I have faright cores on both ends of the usb cord, tried a different usb cord (both brand new), made sure my tuner view isn't in daisy mode, made sure my s300 isn't datalogging.
with all this said im assuming it's my interface module. Am I right?
chickenbandit
HRTuning Thu Aug 21, 2014 6:27 pm
I'm assuming you have an S300 v1 or v2 since it only mentions those two as supported on the website. In that case you'll want to see the TunerView Help and make sure you've pinned the cable properly.
chickenbandit Thu Aug 21, 2014 6:28 pm
yea s300 v2
chickenbandit
HRTuning Thu Aug 21, 2014 6:30 pm
Excellent.
chickenbandit Thu Aug 21, 2014 6:36 pm
can you post a link to it?
chickenbandit
HRTuning Thu Aug 21, 2014 7:04 pm
www.hrtuning.com
TunerView II Help on the right under support.
chickenbandit Thu Aug 21, 2014 7:41 pm
I switched the wires around and the tunerview had no power. Wouldn't even say connecting.
So I put I back to its origanal wiring and its back on and saying connecting.
chickenbandit
chickenbandit Thu Aug 21, 2014 7:43 pm
How do I add an image so I can show you?[/img]
chickenbandit
HRTuning Thu Aug 21, 2014 7:59 pm
Perhaps you switched the wrong two by not facing the cable like the photo on the Help page.
chickenbandit Thu Aug 21, 2014 8:22 pm
Nope. I did it exactly like the picture.
With the lil tab up. I switch the two wires on the left.
It did not work.
Could it be that the previous owner already did that?
My wiring order is (from the left) orange, red, brown, black
chickenbandit
HRTuning Thu Aug 21, 2014 8:26 pm
Left?
NepTune RTP (Old, not Demon), AEM, S300, and K-Pro
The last two pins should be swapped regardless of what color cable you have. For Example: Red Yellow Green White/Orange on one side and Red Yellow White/Orange Green on the other.
chickenbandit Thu Aug 21, 2014 8:34 pm
chickenbandit
chickenbandit Thu Aug 21, 2014 8:38 pm
You're a genius and im a idiot. Can't believe I read it 20 times and misread it every time until you put "left"
chickenbandit
HRTuning Thu Aug 21, 2014 9:29 pm
No worries. All up and running now?
chickenbandit Fri Aug 22, 2014 5:53 am
Yea it connected right away
chickenbandit
