Omni 3 Bar?
Omni 3 Bar?
Tippyman Sat Jul 05, 2014 8:30 pm
I'm trying to set up a tunerview2, but don't see the option for a omni power 3 bar map sensor. When I select the "neektronics 3 bar" (can't remember the name, don't have my laptop with me) it says 0.0 psi with key on engine off, so does that mean it's good to use?
Tippyman
HRTuning Sun Jul 06, 2014 2:30 pm
It will be close, but they're not exactly the same scalar. See if it reads close while running.
Tippyman Sun Jul 06, 2014 2:49 pm
It reads about 17-18 in hg. at idle. The car has a cam so that should be about right. I'll compare it whenever he gets his RTP up and running. Is there any way to input my own MAP values?
Tippyman
HRTuning Sun Jul 06, 2014 2:54 pm
Ok. At 2 volts you're looking at a 5kPA, 50mBar difference. That's pretty close to accurate and you probably won't notice anything "off".
Not on the TunerView, unfortunately.
