Fuel level converter helpppp
LSTURBO9 Wed Jul 02, 2014 2:10 pm
I have fooled the instructions for it using b6 on the ecu put the values in both the rd1 and rtp is the sensor sections using the b6 programmable sensor no reading but if I put it to read voltage I see it working but not how I wasn't it to be no mater what values are put in the sensor section it only moves when I input two values I. The templet wich only let's you do max min and warning what am I doing wrong done it before but not no more
LSTURBO9
HRTuning Wed Jul 02, 2014 2:40 pm
What do you have entered?
LSTURBO9 Wed Jul 02, 2014 3:39 pm
The reading I get in voltage from empty to full
LSTURBO9
HRTuning Wed Jul 02, 2014 3:46 pm
What do you actually have entered?
LSTURBO9 Wed Jul 02, 2014 4:13 pm
0vlt is full 1.33 is half a tank and 2.68 is empty no mater what I put it don't work
LSTURBO9
LSTURBO9 Wed Jul 02, 2014 4:18 pm
Maker a gauge for it so I can try losing my sleep over this
LSTURBO9
HRTuning Wed Jul 02, 2014 5:09 pm
Sounds like you just don't have it entered correctly.
In the RTP software you should have it where the voltage is always ascending:
0 100
1.33 50
2.68 0
In the display you should have it entered the way the example shows it in the software, where the real value is in ascending order regardless of the voltage:
2.68 0
1.33 50
0 100
Don't forget to save your changes.
LSTURBO9 Wed Jul 02, 2014 6:23 pm
did it both ways but ill try again will keep you posted
LSTURBO9
HRTuning Wed Jul 02, 2014 6:35 pm
That was not two ways. One is for the RTP software and one is for the display. They both work, as I tested them here.
LSTURBO9 Wed Jul 02, 2014 6:41 pm
I shuld have been more clear I did bothe the rtp and the rd1 ascending and descending and nothing but will try in a few I have the car parked in a garage in the other side of town and it's hotter than hell outside
LSTURBO9
HRTuning Wed Jul 02, 2014 6:57 pm
Just try it the way I have it and make sure to save.
