does tunerview ll work with crome pro?
thugsbryan Tue Apr 30, 2013 4:45 pm
all along my tuner view was working fine until my tuner put crome pro on the ecu it wont connect anymore
it just says connection
i programmed i correctly and all the cables are connected where they shud be Evil or Very Mad
thugsbryan
HRTuning Tue Apr 30, 2013 4:47 pm
You need to set the display to Crome and setup Crome for datalogging. I can't help with that. There's info on pgmfi.org.
thugsbryan Tue Apr 30, 2013 4:51 pm
HRTuning wrote:You need to set the display to Crome and setup Crome for datalogging. I can't help with that. There's info on pgmfi.org.
ok so its something in the crome settings the tuner need to set for the tunerview to work?
thugsbryan
HRTuning Tue Apr 30, 2013 5:06 pm
You need to set the display to Crome for the system.
You need to enable datalogging in Crome. http://forum.pgmfi.org/viewtopic.php?f=52&t=14026
thugsbryan Tue Apr 30, 2013 5:42 pm
HRTuning wrote:You need to set the display to Crome for the system.
the display is already set to crome system and datalogging was enabled in crome but it still don't connect so I don't know what's wrong
thugsbryan
HRTuning Tue Apr 30, 2013 5:56 pm
Something in those steps wasn't done properly. Perhaps the script version I linked to wasn't used. Unfortunately I can't help you with Crome, so you'll need to get your tuner involved.
thugsbryan Tue Apr 30, 2013 6:22 pm
HRTuning wrote:Something in those steps wasn't done properly. Perhaps the script version I linked to wasn't used. Unfortunately I can't help you with Crome, so you'll need to get your tuner involved.
ok thanls a lot just the same
thugsbryan
HRTuning Tue Apr 30, 2013 6:55 pm
No problem. Hope you can get it solved.
