Display problem with rd1
sloweghatch Fri Apr 12, 2013 4:07 pm
Just installed my rd1 into my eg civic, having an issue that when I turn the key on and power the unit up it just stays black with a line thrue the display. I thought it could be a problem with the unit, but when I plug it into my laptop it turns on, displays the tunerview opening screen then shows a basic layout i did when I first received the unit out of the vehicle. Is there any reason I could be having this problem, also when I try to connect to it in the tunerview program it tries connecting for a few seconds then says disconnected. Could I possibly need to reset the rd1?
sloweghatch
HRTuning Fri Apr 12, 2013 4:53 pm
If it shows up when plugged into USB it sounds like you're not powering it correctly in the vehicle or you have the 4 pin in the wrong location. That can damage the unit.
sloweghatch Fri Apr 12, 2013 5:18 pm
Even with everything disconnected but the usb from the laptop that's what happens. It displays the tunerview screen then shows a layout I had installed and that's it. Is there a way to reset the tunerview.
sloweghatch
Re: Display problem with rd1
HRTuning Fri Apr 12, 2013 5:50 pm
sloweghatch wrote:Just installed my rd1 into my eg civic, having an issue that when I turn the key on and power the unit up it just stays black with a line thrue the display.
This was what I was referring to.
Manually choose the port and hit connect. If it worked before there's no reason it wouldn't work now unless you damaged it.
sloweghatch Thu Apr 18, 2013 9:26 pm
Got the rd1 working. But seem to have fried my xtreme hulog in the process. Is the hulog supported with the rd1, if so which port would i plug it into?
sloweghatch
HRTuning Thu Apr 18, 2013 10:02 pm
If you're datalogging through the TunerView use the USB port.
