10 secs B16A @ 24 psi
boost-si Sun May 01, 2011 6:29 pm
Guys just wanted to share with you that last night I ran 10.92 @ 128.90MPH with a 60Ft of 1.684
I am running 24 psi right now with 374HP( dyno by MY SELF on a land & sea dynomite) I have heard from other shops and tuners that I must ad 15% to this figure to come down on a dyno jet number which would be 430hp.
Will post the video from the 10secs pass and the dyno sheet later when I get home from work.
I can say one thing for me " NEPTUNE RULES"
boost-si
akmotorworks Mon May 02, 2011 5:08 pm
awesome stuff! can you share some of the setup?
akmotorworks
boost-si Mon May 02, 2011 8:39 pm
Sure I can my setup is the following;
Precision SC6262 Turbo, ar 63
Precision injectors 1000cc
3.5BAR AEM MAP sensor
Victor X intake
75mm Edelbrock Throttle body
GSR cams
Supertech valve springs
ARP head studs
Home made Top mount manifold
46mm Ebay wastegate
31x9x3 Ebay intercooler
B18B NPR cast pistons with floating pin option
Eagle rods
ITR oilpump
GSR tranny
Walbro inline fuel pump
Neptune management system
Tuned 75% C16 mixed with 25% pump gas.
Can do better times if I can lower ma 60ft to 1.6 and also change my FD to 4.266 to gain more mph in all gears since my trap RPM is 7500 in the 4th gear.
Might you guys have any other questions do not hesitate to ask..
boost-si
je_lo Fri Aug 31, 2012 11:50 pm
are you running on a lightened car??? your 0-60 is awsome...
je_lo
NepTune'd
