Little background My car was boosted for the past 2
1.5 years using neptune and an omni 3 bar map sensor without issue.
Recently i went NA and switched back to a stock map sensor, wrote a completely new Map for this setup.
I get the tune about 90% dialed and then the map sensor goes on the fritz and starts logging 10.3 psi.
I replaced that oem map sensor with another. Make slight adjustments to the tune, 3 days later that map sensor is doing the same thing. I replace it with a non oem map sensor and make slight adjustments to the tune again, 2 days later intermittently on the fritz again.
Hook up the laptop for live graphing key on engine off map is reading 10.3 psi. Wait an hour, come back outside and check map is reading 0 psi key on engine off. Car starts up perfectly. Go for a 20 minute drive back on the fritz.
I check 5v input at the sensor and i am getting 5v.
Anyone ever see something like this? Having a hard time believing 3 bad map sensors. FWIW I am using a rywire tucked harness also about 1.5 years old, no shorts or open spots in the harness that i can see.
