Feature Request Discussion.
Bruno Mon Aug 27, 2018 2:06 pm
Can we even expect any updates to ever come about?
I had some requests from back in 2015 that have not been resolved. My biggest issue is the F keys in a MAC not working.
Bruno
HRTuning Mon Aug 27, 2018 3:41 pm
I'm unsure what you mean about F keys. If you mean F as in function 1-12, we don't use those at all.
Everything in the quick keys does work unless you have something in the system set to override that for another function.
imtheman0313 Sun Jun 16, 2019 4:11 pm
I would like to see variable setting for ELD control. IE change the point at which the altc begins.
imtheman0313
AKindinos Tue Jun 25, 2019 5:33 pm
Whould be possible to add a function in order for us to be able to change when the TPS-tip in presentage will change? for example I have to depress the accelarator 30-40% for the tps tip-in to kick in and I want it from 10-15%
Is this possible?
AKindinos
HRTuning Wed Jun 26, 2019 10:11 pm
It does not take 30-40% in order for TPS tip-in to become active. It's based on how much change is seen and you can adjust that amount with the percentage setting.
AKindinos Sun Jun 30, 2019 11:05 am
so to be clear if I set the tps tip in at 12 it will activate when it reads a 12% change in tps?
AKindinos
HRTuning Sun Jun 30, 2019 3:50 pm
The setting is a percentage of fuel increase or decrease.
severity Wed Sep 11, 2019 3:45 pm
Hello, would it be possible to change the Preferences->Logging->Parameters->Log A/F Above TPS field to accept negative numbers? I set it to -1 in order to get Neptune to log A/F ratios while idling but whenever I close it and open it again it goes to 255, if you change the variable to a long or float so it can retain negative numbers (not sure what language its written in) that would be awesome! Also, would it be possible to assign a hot key for Edit->Clear All Marks? I like to use it while driving and it can be a bit tricky to use the trackpad Smile
Thanks!
severity
HRTuning Wed Sep 11, 2019 6:58 pm
0 is the minimum. You can view and alter idle a/f while idling.
No hot key we can find that fits this.
GRT Thu Oct 17, 2019 1:04 am
Can i ask about a place where u can change minimal samples rate number that u need for record data in overlay lambda map(think this be very good for many users who make street tuning).
GRT
