fresh swap no start
fresh swap no start
13btoy Sat Jul 20, 2019 6:46 pm
2000 Civic with a fresh B18c1 Turbo running a Neptune Demon/OBD1 P72 along with an HAmotorsport base map. The swap is finally ready for initial start up but I cant get it to start. It will try to fire up but will not continue running. The Neptune is connected under status and I can see RPM, TPS, etc. in the data gauges. The only fault code is ECT. Can you please point me in the right direction? My suspect is the distributor wiring going from the civic 8pin to the B18c1 10pin distributor. The dizzy jumper harness my son had did not work so I just matched the wires according to diagram.
Thanks, Ed
13btoy
HRTuning Sun Jul 21, 2019 1:01 pm
If it starts and you can see real-time data you may just need it tuned. If you have a wiring issue that's not something we can guess at from here.
Like us on Facebook.
http://www.facebook.com/NepTuneEngineManagement
HRTuning
    Send private message View user's profile Visit poster's website AIM Address
13btoy Mon Jul 22, 2019 3:16 am
Made huge progress today. Wiring is sorted out. The car is running. No CEL and holds idle. Just need to work out a couple of little things as with all new builds then I will start tuning. Running super rich at 12 afr at idle and stumbles when you give it throttle. Thanks!
13btoy
HRTuning Mon Jul 22, 2019 3:56 pm
Making progress for sure!
HRTuning
NepTune RTP Software
