Ignition tip in
Ignition tip in
8400rpm Tue Jan 29, 2019 7:17 am
Good day,
A quick question...if i have 'ignition corrections' disabled in options section, will ignition tip in still make corrections(with my tip in conditions all met)?
8400rpm
HRTuning Tue Jan 29, 2019 4:13 pm
From the help:
Ignition adjustments occur all the time. The ECU alters the ignition based on many variables like map sensor voltage, throttle changes, and even rpm changes causing the actual ignition timing to differ from the maps. Unchecking this checkbox allows you to disable adjustments above the specified load. This will give you full control of ignition timing since it will only run what's in the maps, gear correction, individual cylinder correction, iat correction, and ect correction. The load settings allows you to keep a completely stock partial throttle drivability while still giving you full control at higher loads or in boost.
8400rpm Wed Jan 30, 2019 9:06 am
I have read the help.
I need clarification on ignition tip in, as help section says... 'it will only run what's in the maps, gear correction, individual cylinder correction, iat correction, and ect correction.'
It does not mention whether this includes tip in as well or maybe i missed something?
Maybe it means tip in is disabled as well...im just asking for your clarification so i can be sure.
8400rpm
HRTuning Wed Jan 30, 2019 3:10 pm
It's pretty clear what's included in that statement. I'm not sure what you're missing here.
Don't disable adjustments. That's my suggestion to you given this inquiry.
Relic1 Thu Jan 31, 2019 6:21 pm
8400rpm wrote:'it will only run what's in the maps, gear correction, individual cylinder correction, iat correction, and ect correction.'
everything else not mentioned is gone.
be VERY careful with that setting, bad things can happen fast.
one thing I've noticed about the documentation on here, if you need clarification, you're likely overthinking it.
Relic1
8400rpm Fri Feb 08, 2019 8:45 am
Thank you Relic for your help.
I think its a valid question which could have been dealt with more maturity. These forums are here for that after all.
8400rpm
