lambda and % are blank
Asics0413 Sun Dec 03, 2017 9:32 pm
hello i am having trouble getting neptune rtp to display values in lambda and percentage. i have the most recent version. all the gauges are displaying values and specifically the 02 gauge matches up with the physical gauge. i have datalogging enabled and i can watch the selected cell move with the rpm and load but all the cells are blank. i also read where someone could only view his if he looked at them from a recording but that isnt working for me either. i can trace the cells in every other table but these two. hopefully someone has an easy fix for this. attached are two pictures of my logging settings. https://imgur.com/a/v0bTo
Asics0413
HRTuning Sun Dec 03, 2017 10:17 pm
There is an easy fix. See the bottom of your first photo or the preferences section that it was taken from.
After you've made the appropriate changes see Setting Up A Wideband and Working With Air/Fuel in the Help.
hadtstec Wed Feb 21, 2018 11:43 am
I had the same issue and just fixed it
In the Parameters under serial input, remove everything.
(That first picture above should be black and no values entered
hadtstec
