Connection issue with Bluetooth module for Demon ][
amoxin Sat Jul 18, 2015 9:29 pm
This is a new demon ][ and bt module. Turn key to on position, scan for devices on my tablet, tablet recognizes bt module and pairs but won't connect. Usb cable unplugged from demon usb remote extension. Tried a reseat for the bt module. Blue light on bt module blinks fast initially and then slows down. I must be missing something, thoughts?
amoxin
HRTuning Sat Jul 18, 2015 11:35 pm
It actually has to connect to pair, and slows down upon connect. How did you come to your conclusion?
Like us on Facebook.
http://www.facebook.com/NepTuneEngineManagement
HRTuning
    Send private message View user's profile Visit poster's website AIM Address
amoxin Sun Jul 19, 2015 2:36 am
My Bluetooth icon on the tablet doesn't show a connected device. I paid for the tuner view app and configured that, it gives an error saying there is no ecu connected when I select the moates bt module.
amoxin
Linszter Sun Jul 19, 2015 5:13 am
amoxin wrote:My Bluetooth icon on the tablet doesn't show a connected device. I paid for the tuner view app and configured that, it gives an error saying there is no ecu connected when I select the moates bt module.
The TunerView app only show "ECU not foud" whey you scan for bluetooth device and not found any.
When you try to connect with the app you see a list of paired devices and you can scan for new devices. This list is empty?
Linszter
amoxin Sun Jul 19, 2015 7:11 am
The list shows the bt module in the tunerview app, but when I try to connect I get the ecu not found message.
amoxin
Linszter Mon Jul 20, 2015 7:20 pm
amoxin wrote:The list shows the bt module in the tunerview app, but when I try to connect I get the ecu not found message.
Can you record it somehow and upload it to youtube or something?
The "ECU not found" message only shown when you search for new bluetooth device.
Linszter
amoxin Mon Jul 20, 2015 8:38 pm
Video sent to your email.
amoxin
amoxin Thu Aug 06, 2015 10:32 pm
Just an update here, it seems to be connecting to the bluetooth module now. Unfortunately, the gauges are all wacky, showing incorrect information. Has anybody else experienced this?
amoxin
HRTuning Fri Aug 07, 2015 1:57 am
Not unless J12 isn't cut.
HRTuning
4alex01 Sun Sep 13, 2015 10:22 pm
hello, im connected on bluetooth, but my problem its when i use software neptune rtp x and click on "download base code" fail and get disconnect.
4alex01
HRTuning Sun Sep 13, 2015 11:50 pm
If you did Connect Bluetooth instead of Connect USB from the menu it should cut the packet size down enough to work through bluetooth. As always it's suggested to upload and download through USB only.
HRTuning
4alex01 Mon Sep 14, 2015 4:44 am
HRTuning wrote:If you did Connect Bluetooth instead of Connect USB from the menu it should cut the packet size down enough to work through bluetooth. As always it's suggested to upload and download through USB only.
Simple question. Do i need to remove the plastic cover of the bluetooth device?[/img]
4alex01
HRTuning Mon Sep 14, 2015 12:54 pm
I'm assuming that's to protect the unit, but that is not a module I produce. It won't make a difference in your connectivity.
HRTuning
General Questions
