Will Neptune work with my wide band?
This topic is locked: you cannot edit posts or make replies.
whess Mon May 21, 2007 2:59 am
I was thinking about grtting the Neptune RTP. Will It work with the LM-1? When I had the car tuned Jeff had A PLX wide band, I was not sure If I would have to get one to use the logger?
Thanks for you time to help out.
whess
HRTuning Mon May 21, 2007 4:14 am
This is posted in the wrong section, but the RTP software can be setup to use any wideband.
viperjng Tue Nov 27, 2012 10:56 am
Hi,
How do we get the Innovate LM-1 to work with the Neptune. Innovate does not show up on the list.
Jignesh
viperjng
jjkz24 Tue Nov 27, 2012 1:08 pm
viperjng wrote:Hi,
Jignesh
Review the "Getting Started 2" video in the Help menu of Neptune, where it shows you how to setup a wideband.
jjkz24
    Send private message View user's profile Send e-mail
HRTuning Tue Nov 27, 2012 2:24 pm
If you're talking about the direct serial logging, simply choose the port for it in preferences in the direct serial logging section of the Ports tab. Then Start Direct Logging in the Datalogging menu. If you want it to be your main wideband input make sure to choose that as your wideband in preferences as well.
viperjng Wed Nov 28, 2012 4:55 am
Hi,
Thanks for the quick revert. Will try out what you guys suggested. Also made a mistake in mentioning the wideband model. Its Innovate MTX-L. Will the same steps work.
Jignesh
viperjng
Evans Performance Wed Nov 28, 2012 2:13 pm
Direct serial will only work with a serial port or USB. If you can log from that with that method then it will. If it just has a 0-5v wire then you will need to use one if the ecu inputs.
:: Whitty Signature Here ::
Evans Performance
HRTuning Wed Nov 28, 2012 3:00 pm
Yes, PLX works for direct serial logging.
Or you can use one of the ECU inputs as mentioned.
viperjng Thu Nov 29, 2012 7:29 am
Hi Guys,
Thanks a lot for the answers. All sorted out and is data logging now.
Jignesh
viperjng
HRTuning Thu Nov 29, 2012 2:30 pm
Very good. Smile
NepTune Logger
