map sensor Q
map sensor Q
H23V Sat May 28, 2011 1:39 am
What do u think the best map sensor is out there
jason morris
H23V
    Send private message View user's profile Send e-mail
hjdanzi Wed Jun 15, 2011 7:30 pm
For a stock car, the stock one. For a forced induction application i found out that omnipower maps are cheap and reliable and their configuration is widly known and predifined in all tuning software.
I also tried Delphi (sucks), GM (sucks) and Magnetti Marelli (the worst thing ever).
PUBLIC GARAGE TUNING
ONLY HONDA TUNER IN ARGENTINA
http://www.publicgaragetuning.com.ar
hjdanzi
    Send private message View user's profile Visit poster's website MSN Messenger
moozregie Thu Jun 16, 2011 6:01 am
recently heard of the SF stock replacement 4bar
haven't heard any reviews but they sound great from their claims
SF 4 Bar MAP sensors use state of the art bipolar op amp circuitry with thin film resistor networks built into each micro chip. Pressure changes are calculated on a true linear 0-5 volt scale via a specially designed silicon pressure sensor that also compensates for temperature changes. The unique ability to compensate for temperature changes allows our MAP sensor to remain a minimum of 99% accurate from 32 degrees F to 180 degrees F through out its range of scale. With the true linear pressure vs. voltage scale there is never a need to re-tune at different altitudes as with other sensors. SF 4 bar MAP sensors can precisely calculate boost pressure from 1-43+ psi while still allowing smooth stock OEM driveability at any boost level. Conveniently packaged in an OEM dimensional housing for easy install and an OEM look.
Key features:
* 40 to 260 degrees Fahrenheit temperature operating range
* Able to respond from 10% of the pressure scale to 90% of the pressure scale in .001 seconds (the fastest response time of any MAP sensor on the market).
* Automatic temperature compensation.
* True linear scaling for perfect drivability at all boost and vacuum levels.
* Compatible with all aftermarket engine management systems.
* Minimum of 99% accurate over full scale range under all conditions including temperature, altitude, and humidity changes.
* Allows smoother engine operation, higher boost levels, and better drivability than competitors turbo MAP sensors.
* Direct plug and play for an easy install and an OEM look. Dimensionally identical to the stock MAP sensor.
* Each sensor is hand assembled, pressure, and function checked in the USA for unparalleled quality control prior to shipping
moozregie
    Send private message View user's profile AIM Address
CainTuned Fri Jun 17, 2011 2:43 am
ya Speedfactorys map sensors work great they are a local shop around me and ive seen alot of them in use
Theres No Replacement For Displacement
Clarification Is Worth A Million Bucks
CainTuned
NepTune Chip Based Questions/Comments
