stwatson wrote:It is hooked to a switched ignition source. When you turn the key to start the car, the power is momentarily cut as you turn the key to the cranking position.
HRTuning wrote:As soon as the key gets turned from the off position, it should have constant power to the module.
Find a different power source. It cannot be cut during cranking. Since the ECU is powered full time it produces some feedback through USB to the module keeping it running during this cycle of power even though it doesn't have enough power to run properly (Supply power has been cut). This does not reset the module when power returns, causing it not to go through the powerup connection phase to regain communication.
